Engine Comparison - 1994-1997 Power Stroke FAQ
2034 Views 1 Reply 0 Participants Last post by  DieselStop Content
Engine Comparison
Courtesy of: Ford Motor Company Publication 2124-002 REF
7.3 DI TURBO7.3L IDI TURBO7.3L NA
ENGINE SPECIFICATIONS
TYPE
Diesel, 4-Cycle Type, Direct InjectionDiesel, 4-Cycle Type, Indirect InjectionDiesel, 4-Cycle Type, Indirect Injection
CONFIGURATION
OHV V-8OHV V-8OHV V-8
DISPLACEMENT
444 cu. in. (7.3 litres)444 cu. in. (7.3 litres)444 cu. in. (7.3 litres)
BORE & STROKE
4.11 x 4.18 in. (10.44 x 10.62 cm)4.11 x 4.18 in. (10.44 x 10.62 cm)4.11 x 4.18 in. (10.44 x 10.62 cm)
COMPRESSION RATIO
17.5:121.5:121.5:1
ASPIRATION
Turbocharged with Back Pressure Device for warm-upTurbocharged with Wastegate ControlNaturally Aspirated
RATED POWER
210 hp @ 3000 rpm190 hp @ 3000 rpm185 hp @ 3000 rpm
RATED TORQUE
425 lb.-ft. @ 2000 rpm395 lb.-ft. @ 1400 rpm360 lb.-ft. @ 1600 rpm
TOTAL WEIGHT - DRY
920 lbs (417 kg)900 lbs (408 kg)860 lbs (390 kg)
COOLING SYSTEM
WATER FLOW
80 gpm @ 3300 rpm79 gpm @ 3000 rpm80 gpm @ 3300 rpm
THERMOSTAT LOCATION
In Water Pump HousingWater OutletWater Outlet
WATER PUMP
Centrifugal TypeCentrifugal TypeCentrifugal Type
WATER PUMP ROATIONS
ClockwiseCounterclockwiseCounterclockwise
FAN HUB
Right-Hand ThreadLeft-Hand ThreadLeft-Hand Thread
LUBRICATION SYSTEM
TYPE
Full FlowFull FlowFull Flow
CAPACITY (INCLUDING FILTER)
12 U.S. Qts. (11 liters)10 U.S. Qts. (9.5 liters)10 U.S. Qts. (9.5 liters)
OIL PUMP
Gearotor PumpGear PumpGear Pump
OIL COOLER
30 Fins per inch30 Fins per inch24 Fins per inch
LUBE OIL SYSTEM
Enhanced for New Injection SystemNot ApplicableNot Applicable
LUBE OIL FILTER
Microglass - ExtenderCelluloseCellulose
OIL FILTER MOTORCRAFT/PART NUMBER
FL-1995/F4TZ-6731-AFL-784FL-784
OIL DRAIN INTERVAL
3000 - 5000 miles with microglass filter2500 - 5000 miles2500 - 5000 miles
HIGH PRESSURE LUBRICATION SYSTEM
HIGH PRESSURE PUMP
Gear Driven Swash PlateNot ApplicableNot Applicable
PRESSURE CONTROL
Pulse-Width Modulated Pressure Regulated Spill Valve (EEC-V)Not ApplicableNot Applicable
OIL RAILS
High Pressure Rails in Cylinder HeadsNot ApplicableNot Applicable
OIL LINES
High Pressure from Pump to RailsNot ApplicableNot Applicable
LUBRICATION OIL TEMPERATURE
Used for Injection Control StrategyNot ApplicableNot Applicable
FUEL SYSTEM
TYPE
Electronically-controlled Direct InjectionMechanical Indirect InjectionMechanical Indirect Injection
SUPPLY SYSTEM
Pump
Mechanical Tandem: Diaphragm/PistonMechanical Single DiaphragmMechanical Single Diaphragm
Filter
Replaceable Element (FD-4595A/F4TZ-9N184-B)Conventional Spin-OnConventional Spin-On
Return
Flow RegulatedPump and Injector Leak-OffPump and Injector Leak-Off
FUEL DELIVERY AND CONTROL
System
Unitized InjectorsMechanical Pump, Lines and Injection NozzlesMechanical Pump, Lines and Injection Nozzles
Injector Actuation
Hydraulic/ElectricalMechanical HydraulicMechanical Hydraulic
Injector Timing
Electronic Controlled by EEC-V (not adjustable)MechanicalMechanical
Fuel Control
ElectronicMechanicalMechanical
Diagnosis
EEC Quick Test, Diagnosis with Super Star Tester II, Pressure GaugesPressure Gauges, Timing MeterPressure Gauges, Timing Meter
ELECTRONIC ENGINE CONTROLS
SYSTEM
EEC-VNoneNone
INJECTION CONTROL
Injector Driver ModuleNot ApplicableNot Applicable
CYLINDER HEAD
COMBUSTION CHAMBER DESIGN
Re-entrant Chamber in PistonPre-Combustion Chamber in HeadPre-Combustion Chamber in Head
ROCKER ARM ASSEMBLY
Plate-Type Valve LeverStamped SteelStamped Steel
EXHAUST VALVE MATERIAL
Made of Hot Forged 21-2n MaterialMade of Iconel for Temperature ResistanceMade of Chrome-Plate Steel
OIL RAILS
FUEL PASSAGES
In Cylinder HeadsNot ApplicableNot Applicable
CYLINDER BLOCK
CYLINDER BLOCK MATERIAL
Cast IronCast IronCast Iron
PISTON MATERIAL
Aluminum-Alloy, Cast in Ni-Resist InsertAnodized, Aluminum-Alloy, Cast in Ni-Resist InsertAluminum-Alloy, Cast in Ni-Resist Insert
Integral CombustionNot ApplicableNot Applicable
PISTON RINGS
#1 Full Keystone,
#2 Taper Faced,
#3 Two Piece Oil
#1 Full Keystone,
#2 Full Keystone,
#3 Two Piece Oil
#1 Rectangular,
#2 Taper Faced,
#3 Two Piece Oil
CONNECTING ROD DESIGN
Forged Steel
Larger Connecting Rod Bore for Wrist Pin
Larger Boring Surface
Forged Steel
Forged Steel
Smaller Bore for Smaller Wrist Pin
PISTON PIN BORE DIAMETER
1.3086 in. (21.45 cm)1.3086 in. (21.45 cm)1.1104 in. (18.2 cm)
See less See more
1 - 1 of 2 Posts
1 - 1 of 2 Posts
