Discussion Starter #2
Only got 35 out of 42 on my early 99 the nut on the other side of the harness is broken thinking there was movement in there truck wont idle on it's own
Yep, empty pin slots are common. As long as the mating connector matches up, you're good to go.
Here's the pinout diagram for that connector. It's for a 99-01 truck. There may be some changes for '02 and newer.
Discussion Starter #6
Thank you think I'm good got her running Decent after rebuilting IPR then my tranny went so I got another post up on what rebuild kit I should use for a truck that will be used to transport thanks for the help and Diagram I save it
