I just completed rebuilding engine. Would it be wise to start the engine outside of the truck with the turbo off just to make sure it runs? Should the engine, for any reason, not start?
I checked the oil pump, looked brand new. IP has 120K on it, now turned up. Injectors and injector lines are brand new. Removed mech. fuel pump and converted to elec. by the tank. Oil cooler is original, with new seals. Water pump ais original. New T-stat. Faulty valves were replaced. New return lines and T's. New bearings. And of course, the reason hte engine was pulled: all 8 were resleeved.
Sound good?
Sound good?
