1 - 9 of 9 Posts
I lost the rear engine lifter bracket during the rebuild. Went to the stealership and they said that they werent available anymore. Does anyone know where I can get one?
Also, shouldnt there only be two of them? one above cylinder #2 and one above Cyl. # 7? Or should I have 4?
Check this pic for the factory locations.......2 pax side and one drivers side rear, I always use an extra bolt for a 4th chain on the front of drivers head where accessories came off.
IH never carried them as they "were a Ford part"... They claimed that ford installed them...? /ubbthreads/images/graemlins/shrug.gif
Ford doesnt make them anymore. Time to get the forge & plasma cutter out.
Thanks for yalls help
RA
No junkyards near you? I would imagine if you looked for Ford trucks or vans, you'd find one with a 7.3 or a 460. On my truck, the bracket at the #7 cylinder has the three way tee for the return lines. You don't want some ugly brackets on your engine, do you?
Discussion Starter · #9 ·
No, but I can fab stuff well. Plan was to cut some 1/4" steel with the plasma cutter and grind the edges smooth, then 7/16" holes for the mounting bolts. for the large hole I was probably going to use a 1 1/8" pipe notcher to borea hole for the chain. Id then heat it in the thingy...hell, whats it called...propane furnace thingy... anyways, and slowly bend the edge around a 1/2"-3/4" piece of pipe until at the right angle. Id then cool it down with some oil to give strength to the steel (ancient japanese meathod, works).
You may have just challenged me (condemned me) to making one... /ubbthreads/images/graemlins/biggrin.gif /ubbthreads/images/graemlins/smokin.gif
Time will tell...and my lazy side- if it attacks, then its off to the J-yard... /ubbthreads/images/graemlins/tongue.gif
1 - 9 of 9 Posts
