Does anyone have a good set of daignostics links for an 2001 SD? I haven't been able to buy the manuals yet since I've only had the truck for 5-6 weeks.
I did a bunch of updates last week and this week, and driving it today (just got it running again this morning) it started acting really bad. The same feeling of trembling and jerking as a friends truck that we know is running low on fuel pressure in his common rail system.
I am really just starting to get familiar with these and don't know what procedure to do to check things. I do know that the fuel pressure is there from 60-70psi depending how I set the return regulator. I put back in the stock CPS I had and didn't seem to make any difference. Other than that, I don't know what to check next.
Reprogrammed the stock program into the computer, to no avail.
Should I put a gauge on the Injector Oil system to see what it reads?
Please help and thanks in advance.
Here's what I've just finished doing:
2001 F350-SD Crew Cab LB
4" Turbo Back w/Flow Master
Tank pick-up mod
Added oil-crossover
Severe Service Filter Assy
SCT Livewire
ATS Trubo Housing & Compressor wheel
Fuel Pressure Return Regulator
Heater Delete
Harness for EBV code over ride
Wrap Intercooler Outlet
Wrap Turbo & Downpipe
EGT Probe.
Tank pick-up mod
Added oil-crossover
SCT Livewire
Heater Delete
EGT Probe.
