1 - 8 of 8 Posts
I recently purchased a used 2011 F250 SD 6.7 powerstroke diesel with 28,000 miles. It was manufactured in May 2010, and I read there is a problem with the glow plugs on vehicles manufactured before March 2011.
My question is was there a problem with all early models, and should I consider changing mine?
Also, any recommendations/experience with engine oil additives. I read that Turbo Maxx is an excellent additive as well as Archoil.
Opti-Lube Summer Plus and AR6200 for me. Both improved fuel mileage and AR6200 improved low-end power as well.
The 2 piece glow plugs with the early 2011 model tended to self destruct as the truck approached 100,000 miles. I would have them changed as a precaution.
Here is a fuel additive that I have seen good reviews of on another forum. The good words came from long time diesel owners. I may try it when the Opti-Lube runs out.
TDR-S : Amalgamated, Inc.
Oops, just realized that you were asking about OIL additives. I use AR9100 from Archoil. Since I added it right before an 11,000 mile tow trip, I can't say what, if anything, changed. But I averaged 12.5 MPG towing a 10K fifth wheel.
Cetane boost of +7...pretty high.
I see it mentioned frequently on the Turbo Diesel Register forum that is mostly for Cummins, but rarely anywhere else unless I bring it up. They do have a commercial (fleet) link or two showing good benefits for their product as well as individual users who swear by it.
Thanks for the reply, I will take the advice on the oil additive and have the glow plugs changed. I bought the truck used with only 28,738 miles on it so I'm pretty sure they are original.
Thanks all for the info. Since this is my first diesel pickup any and all information is helpful.
1 - 8 of 8 Posts
