hi, I have noticed that there are lots of people who are having problems when turning the engine off, It shakes and shudders, the engine has a butterfly in the intake manifold and its not working, solution, find the vacuum pump then follow the pipes to the intake manifold, there may be a pipe that's come off, the butterfly is an actuator and needs vacuum to work the butterfly so the engine stops smoothly, basically get someone to see if the actuator is working then you should be able to figure it out, I am from Australia so hopefully someone gains some knowledge as forums have helped me a lot, thanks and have a nice day.
