my truck all of a sudden started to sputter like it was running out of fuel. i made it home with stalling once but i had to keep reving it up.
i drained some of the fuel there was no water so went to start it but batteries were too low.
charged them up ,started the truck up. ran fine, drove about 12 miles then it started top cough and sputter again.
this time drained the fuel filter holder completely cleaned out alot of muck in the bottom and replaced fuel heater.
it fired right up and idled great, reved it up allright ,drove down the road 200 feet sputtered and died . i could turn it overand it would run for a few seconds and then die.it would run a little longer if i kept reving it up .after about 4 starts the batteries were dead .
after charging the batteries it fires up idles good ,reves up,so i drove up and down the road then it started to act up again.
i started and shut it off twice to drain the batteries some . on the third start i tried to drive it but it was worse.
Could bad batteries cause it to act like its running out of fuel?
the gauge show its charging but after two starts it goes into the low reading. i thought that the batteries were only needed to start if the alternator was working allright.
Also , i heard there is a screen that needs cleaning as well as afuel filter. i have no idea where it is.
i have a 1996 7.3 manuel 5spd.
any help or ideas would be very apperciated .
thanks.
thanks.
