Hey guy's,
My 97' with 145K miles has recently developed a problem that when I first start off for work in the morning within a few blocks the engine cut's out momentairly then start's up again as if the key was turned on and off quickly. Say from 2100 rpm's down to 1000 rpm's. And it has died on me when at a stop. Starts right back up and after four or five miles of running it's fine. Sounds almost tempertature related? Im gonna try replacing the cps but if anyone has any other suggestions they truly would be appreciated. I did already change the fuel filter, air filter,
oil and oil filter.
Thank's in advance,
Bill
Re: Engine cut's out.......
Sounds just like the CPS. If it still acts up (and you've got a chip on the PCM) try pulling the chip off. Mine acted like the CPS was bad and I changed it (twice). The chip was the problem... Kevin
