So I figured out my earlier question regarding the exhaust back pressure gauge installation for the Isspro EV2 with electric sensor.
I ended up using an 8 inch piece of 3/16th brake line with one coil in it to adjust for height....a couple adapters to take the brake line to 1/8 inch npt, and one junction block so I could plug the factory sensor in one side and the Isspro sensor into the other side. The factory sensor is on the left, and the Isspro sensor is on the right....in the close up picture.
I attached the whole assembly to the fitting where the factory back pressure sensor was originally located.
It all fit with plenty of clearance under the cover.
Nice job! Looks great!
