Yes they will bolt on, they are are longer from the axel back. Bolt may need to be changed. Spring rate is a little heaver than stock SD but they have less arc so probley will lower truck. You will loose your overload top spring if you have one...could take springs apart and build a custome set...thats what I plan on doing, I have 2 sets of SD's and Excursion springs.
Cary
