ok, I am not sure if I did something wrong here or not, but when I took off the exhaust tubes to the egr, I put the probe from the tube into the block off plate that is tapped for it down at the manifold, now it reads on my H&S 42 degrees , which is what is the outside temp right now..lol, did I do something wrong? I was under the impression that you put that sensor into that plate, I really want to keep a eye out for the temps, and question two is, which pryo do you run, 1 or 2 ? thanks in advance, TJ
