Vendor
Whatever you're doing, at some point you're going to end up with a bed full of gear sliding around and banging into the bedsides. With Putco's innovative Molle Panels, your gear will always stay organized and secured, and easily accessible.
The Molle Rack system is custom engineered to fit directly to each make and model using the existing OEM mounting points in the bed. Panels are cut from heavy gauge aluminum and are rated to hold up to 200 lbs each. Molle Panels are perfect for storing bags, tools, shovels, axes, high lift jacks, Rotopax, Maxtrax, and any other gear you need for your next adventure.
Make your purchase now and earn up to $120 cashback! Do not hesitate any longer! This offer expires on December 31, 2021. Please check the following PDF form to get your reward.
Putco® - Full Assembly Bed Molle Rack System
Features:
  • Custom fit designs engineered for every make and model
  • Perfect addition for over-landing builds
  • Black mini-texture powder coat finish
  • Provides clearance for factory tie downs and access to bedside outlets and lighting
  • Allows you to mount anything from MOLLE bags, trail gear, tools, high lift jacks, axes, shovels
  • Compatible with Backflip tonneau covers
  • Backed by Putco’s limited 3-year warranty
