Anyone else experience this problem. The exterior temp. display on my automatic climate control displays erratic temperatures. When moving along at 35 - 50 mph the temp would be accurate, let's say 70 degrees as I start to slow down the ext. temp display would start to slowly drop down to 50 degrees, outside temp is still 70. After shutting off the engine and coming back to the vehicle 2+ hours later the ext. temp display would indicate 34 degress, outside temp is still 70. Dealer has changed out head unit and outside temp sensor and it's still not reading properly. Somebody HELP ME ! ! ! ! The problem is with the 05 F350.
