1 - 8 of 8 Posts
I somehow missed the 5 speed, so my reply was way off.
· Super Moderator
First off you are going to have to know what rear end gears that you have. There is a tag on the rear end housing that will tell you if you know how to read it. Other than that there is a sticker on the door panel that will have the code, then you can go here to find out what it is.
If you have 3:55's then the RPM's are high but if you have 4:30's then they are about right.
As for the CEL 99% of the auto part stores can not read the codes from a Ford diesel with the code readers that they have. They have to have one that will read Ford propriety codes.
There were no 4.30s.
Is this a pickup or C&C?
By definition it's not the turbo. RPM/speed ratio is determined by transmission and diff ratios, and by tire size. Have you checked the speed against a GPS?
The FLAPS cannot obtain diagnostic codes from our trucks. You need a device that understands the "Ford Enhanced" protocol.
Just for reference, my 94 with 4.10's and 5-speed used to run about 2550 rpm at 70 mph (with 235-16 tires). Cheers!
1 - 8 of 8 Posts
