1 - 1 of 2 Posts
Moderator
F-250-350 Series Technical Service Bulletins
Courtesy of: Ford Motor Company
The "? KB" following the TSB number is the size of the linked Adobe Acrobat .pdf.
If there is no "? KB" following the TSB number, that TSB has been formatted for the web and the Adobe Acrobat .pdf may be downloaded from that page.
ARTICLE TITLEARTICLE NO.MODEL YEAR
94959697
Transmission/Clutch/Driveshaft/Axle
AXLE - 4X4 - "Ratcheting" Noise - Self-Engagement Of Automatic Hub Locks - F-250 And F-350 Over 8500# GVW97-06-27 (79 KB) XXX
AXLE - Leaks - Hub Seal Leak - Vehicles With Ford Design Full Floating 10.25 Inch (260mm) Axles94-19-24 (17 KB)X
AXLE - Lubricant Leaking From Rear Axle Seal(s) - Sub-Zero Temperatures - Vehicles With 10.25 Inch Ring Gear Full-Floating Rear Axle98-05A-27 XXX
CLUTCH - Clutch Does Not Disengage - Leaking Clutch Slave Cylinder - All Diesel Engine Vehicles95-04-09 (5 KB)XX
CLUTCH - Hard To Disengage Or Frequent Replacement Of Clutch Slave Cylinder - Early Wear-Out Of Slave Cylinder97-22-17 (4 KB)XXXX
DRIVELINE - "Clunking" Or "Grunting" Noise During Acceleration Or Stopping - 4X4 - 1992-96 F-150/F-250 Under 8500 Gross Vehicle Weight (GWV) And 1992-95 F-250/F-350 Over 8500 GVW96-23-20 (5 KB)XX
DRIVELINE - "Moan" - From Driveline At 1400-1700 RPM - F-350 Crew Cab 4X4 Vehicles With E4OD Transmission Only95-09-11 X
DRIVELINE - Vibration/Noise - When Driving In 4X2 Mode With Hubs Locked - 4X4 Models97-13-22 (41 KB)XXXX
E4OD - Separator Plate Identification - Service Tip94-18-12 X
FLUID - New Rotunda Fluid Changer - Service Tip95-16-10XXXX
FLUID - Transmission Fluid Usage Charts01-15-07XXXX
TORQUE CONVERTER - Leak Test Procedure - Service Tip96-24-09 (34 KB)XXXX
TRANSAXLE - Torque Converter Replacement Guidelines And Torque Converter/Transaxle Cooling System Cleaning Procedures - Service Tip96-26-12 (9 KB)XXXX
TRANSMISSION - All - Vehicle Can Be Shifted Out Of "Park" Without Depressing Brake Pedal - Econoline Cutaways Only And F-Series Built Through 2/28/9596-08-18 (14 KB)XX
TRANSMISSION - C6, E4OD, AOD, 4R70W - Low Transmission Fluid Level And/Or Shift And/Or Engagement Concerns - 4X4 And AWD Vehicles Only97-12-13 (5 KB)XXXX
TRANSMISSION - E4OD - "Do Not Service" Tag Providing Special Contact Instructions Before 12/1/94 - Vehicles With 5.8L Gas Or 7.3L Diesel Engines94-06-17 (58 KB)X
TRANSMISSION - E4OD/4R100 - 1989-99 - Main Controls, Separator Plates And Separator Plate Gaskets Usage Chart98-16-08 (23 KB)XXXX
TRANSMISSION - E4OD - 7.3L DIT Engine - Overdrive Cancel Lamp Illuminated And Diagnostic Trouble Code (DTC) P1728 - Vehicles Built Prior To 9/20/9596-10-14 XX
TRANSMISSION - E4OD - 7.3L DIT Engine - Overdrive Cancel Lamp Illuminated, Diagnostic Trouble Code (DTC) P1728, And When Reverse And/Or Manual Low Are Selected - Vehicles Built Prior To 9/20/9596-10-14 XX
TRANSMISSION - E4OD - Delayed Forward Engagement And/Or Heat Stained Forward Clutch Plates After Installing Center Support Service Kit F4TZ-7A130-B95-11-13 (30 KB)X
TRANSMISSION - E4OD - Diagnostic Trouble Codes - Water Intrusion Of The MLP/TR Sensor95-02-12 (5 KB)X
TRANSMISSION - E4OD - Direct Clutch Plate Usage Chart - Service Tip95-25-13XXX
TRANSMISSION - E4OD - Engine Stall During Engagement97-24-23 XX
TRANSMISSION - E4OD - Excessive Bushing Wear - Low One-Way Clutch Malfunction94-23-18 (945 KB)X
TRANSMISSION - E4OD - Flashing Transmission Control Indicator Lamp (TCIL) With Diagnostic Trouble Codes (DTCs) 62, 628 And/Or 1728 Stored In Memory98-04-19 (6 KB)XXXX
TRANSMISSION - E4OD - Fluid Level Indicator Damaged On Vehicles Built Through 2/10/94 With A 7.3L Indirect Injection Turbo Diesel94-16-21 (3 KB)X
TRANSMISSION - E4OD - Forward Clutch Wear94-23-18 (945 KB)X
TRANSMISSION - E4OD - Forward/Reverse Sun Gear Service Information94-05-15X
TRANSMISSION - E4OD - Harsh Shifts - F-250-350, E-350, And Cutaway Equipped With 7.3L Diesel Engine Built Between 5/15/96 And 7/8/96 - California Calibration 6-90P-R11 Only96-21-16 X
TRANSMISSION - E4OD - Harsh/Delayed 2-3 Upshifts - Vehicles With 7.3L Diesel And 49-State Calibration - F-Series Built Through 2/3/97 And All 1996 E-35097-06-29 XX
TRANSMISSION - E4OD - Heat Stained Overdrive Planetary Gearset, Coast Clutch Cylinder Bushing And/Or Overdrive Cylinder Bushing95-21-09 (17 KB) X
TRANSMISSION - E4OD - Intermediate Brake Drum Assembly Usage - Service Tip95-16-19 (3 KB)XX
TRANSMISSION - E4OD - New Design Elastomeric Gaskets For Main Control Cover And Bottom Pan96-03-22 (4 KB) X
TRANSMISSION - E4OD - New Design Intermediate Band Apply Servo Assembly95-23-14 (9 KB)XXX
TRANSMISSION - E4OD - New Design Overdrive Clutch Piston Assembly For Some 1996-97 Vehicles - Vehicles Built From 12/5/95 Through 6/15/9696-21-15 XX
TRANSMISSION - E4OD - New Design Reverse Clutch Assembly - Transmission Built From 3/26/9797-17-25 (46 KB) X
TRANSMISSION - E4OD - New Design Transmission Range Sensor (TR) And Connector Included With All E4OD Remanufactured Transmissions95-06-19 (69 KB)X
TRANSMISSION - E4OD - Orange Tag On Transmission Pan - "Do Not Service" - Service Procedures94-16-22 (13 KB)X
TRANSMISSION - E4OD - Overdrive On-Way Clutch - Service Tips95-06-18 (3 KB)XX
TRANSMISSION - E4OD - Overheating - Converter Cover Discoloration, Clutches Burned, Burnt Fluid94-23-18X
TRANSMISSION - E4OD - Possible Water Intrusion Into The MLP/TR Sensor Causing Shift Concerns And/Or Harsh Engagement Concerns95-02-12 (5 KB)X
TRANSMISSION - E4OD - Reverse Clutch Piston And Piston Seal Usage - Service Tip96-07-28 (5 KB)XXX
TRANSMISSION - E4OD - Revised Design Forward Planet Thrust Washer - Service Tip96-24-18 (51 KB) XX
TRANSMISSION - E4OD - Revised Rear Case Bushing95-11-12XX
TRANSMISSION - E4OD - Rotunda Transmission Tester Overlay Cable 007-00107 - Service Tip95-01-10 X
TRANSMISSION - E4OD - Service Case Replacement Service Tips For 7.3L Diesel Vehicle Applications98-13-21 (21 KB)XX
TRANSMISSION - E4OD - Service Information For Orange-Tagged Transmissions94-18-11 (12 KB) X
TRANSMISSION - E4OD- Shift Concerns And/Or Harsh Engagement Concerns Due To Water Intrusion Of The MLP/TR Sensor95-02-12 (5 KB)X
TRANSMISSION - E4OD - Torque Converter Making Dragging Or Scraping Noise During Assembly - Vehicles With 7.3L Direct Injection Turbo Diesel - Service Tips94-21-15 X
TRANSMISSION - E4OD - Unique Overdrive Ring Gear, One Way Clutch Retaining Ring And Shaft Retaining Ring - Service Tip96-21-17 XX
TRANSMISSION - E4OD - Upgrade - Ball Bearing Center Support Service Kit94-24-15 (129 KB)X
TRANSMISSION - E4OD - Upgraded Components To Be Installed During Teardown94-23-18 (945 KB)X
TRANSMISSION - E4OD - Upgraded Overdrive Planet Assembly And Input Shaft When Replacement Of Either Becomes Necessary94-21-13 (22 KB)X
TRANSMISSION - E4OD - Vehicle Does Not Move - Diagnosis And Service Tips94-21-14 (26 KB)XX
TRANSMISSION - E4OD And C6 - Installation Instructions For "New Unitized Plastic Cage" Low One-Way Clutch - 1989-94 Models With E4OD And All Model Years With C694-08-20 (40 KB)X
TRANSMISSION - E4OD And C6 - No Forward Engagement - Service Tips For Installing "New Unitized Plastic Cage" Low One-Way Clutch - 1989-94 Models With E4OD And All Model Years With C694-08-20 (40 KB)X
TRANSMISSION - Torque Converter Replacement Guidelines And Torque Converter/Transmission Cooling System Cleaning Procedures - Service Tip96-26-12 (9 KB)XXXX
TRANSMISSION - ZF - Loctite Sealant Usage - Vehicles Built From 2/2/9494-17-13X
TRANSMISSION - ZF Manual - Use Of Synthetic Mercon Transmission Fluid, Service Tips - Vehicles With 7.3L Direct Injection Diesel Engine Built After 2/2/9494-08-19X
1 - 1 of 2 Posts
