Hi everyone, I was wondering if anyone can answer this, I have lifted my old truck here about three months ago, 4" with 35" BFGs. Looks good, but at or about 25 mph the truck has a shake or a shudder to it when you hit the peddle alittle hard. You can easy into it and it doesn't happen? What gives? Any help???
what year? carrier bearing? you will get lotts of possibles very soon.
How far did you drop it? I went from a 2" rear block to a full 4" rear block and mine required dropping the bearing a full inch to eliminate takeoff shudder.
It has the 5 1/2" blocks in the back but I removed the 2" oem blocks and the carrier bearing drop is an inch or better.
