I have recently purchased a 05 F350 V8 6.0, prior to the purchase I had codes pulled by a mechanic.
Rectangle Font Parallel Slope Terrestrial plant
Font Rectangle Parallel Paper Paper product
From this information I was told it best to replace all 8 fuel injectors. I haven't worked on diesel engines in the past but am relatively proficient on gas engines. Any thoughts would be appreciated. Getting 13.5mpg otherwise truck seems to run good. Do I need to replace the FICM?
Rectangle Font Parallel Pattern Wood
There's a lot smarter guys than me here and they'll come along shortly to help you. In the meantime I'll throw in my 2c worth - there's nothing in that report that would make me rush out to buy one, let alone eight injectors. Ditto for the FICM.
First thing I'd do is Google Forscan and get me a dongle either for my phone or computer. I use an OBDLink - I think its an MX BICBW about that and its 3500 miles away from me right now so I can't go look at it. And I'd wait for the smart fellers to show up. Welcome aboard - this is a good place.
thank you i appreciate that
'02 7.3L Excursion 3.73 Warn Hubs AutoTranny
you will get the Best Results using a USB cable to a Windows Laptop with ForScan loaded on it.
this is the USB cable to OBDII port adapter
Reactions: bismic
