working on f350 with 225,000 hard work miles it's stock has no power it sat for the weekend i started it sunday night to pull it in the back yard ran rough could put padal to the floor with no power. Got home today hooked up the autoenginuity got these codes
c1284
b1352
p0261
p0264
p0267
p0270
p0273
p0276
p0278
p0279
p0282
p0284
p0401
do you guys think it might be the ficm also has a fuel leak on the fuel bowl
:sick:
what year is the truck?pull the fuel filter cap and check for failed or nicked o-ring...use oem filters?pull and clean the egr valve/check for a pink dot on it=the updated one...it should be used...also load test both batts and check the ficm voltage when the engine is cold...b
X2--- FICM, Batteries, egr valve, pcm Page 66: Electrical Components
Do you have the battery cover on the drivers side battery to keep the water off it?
2 stroker:ford:
SORRY IT'S A 03 LOOKS LIKE IT'S COMING OUT THE SIDE BY THE FUEL REG. THE VOLTS WERE 40 PUT THAT IS AS LOW AS IT GOES TILL I LEARN HOW TO SET IT LOWER STILL NEW AT IT THERE IS NO COVER ON THE BATTERY AND BOTH ARE GUNKED UP BAD GOING TO WORK ON IT WHEN I GET HOME FROM SCHOOL
You seriously need to have those batteries LOAD TESTED separately, before testing the FICM. If they fail replace them with the proper batteries.
It means absolutely nothing to check the FICM without testing the batteries first. The way these things are wired, you might think that since it turns over rapidly that the batteries are fine, but that is not necessarily the case. The batteries can be junk and still turn the truck over, but not have enough juice to fire the injectors. Keep cranking it like this and risk damaging other components. Load testing is VITAL.
After load testing, but before rechecking the FICM, remove the FICM from the truck. Check all the pins to make sure they are straight in line and not bent out of place or corroded.
Plug each plug in and make 100% certain that the plugs are seated properly. If the plug is off just a hair, that will cause a problem. Both locks need to click on each plug. It isn't always as easy as it sounds.
Once you have done those few things, then check your FICM voltage readings with key on, engine off and cranking.
Next would be to order this from Tousley Ford. It not only has the parts needed to fix your leak, it also has the parts to replace the weak stock fuel pressure regulator spring. There is an awesome write-up thread on here that would help you install it. Its rather easy and will cure your leak and save your injectors from low fuel pressure.
