Status
Not open for further replies.
21 - 38 of 38 Posts
Banned
Discussion Starter · #21 ·
Good deal!! Do report on the XDS2's so I know what to expect!! Kill me with details so I can put my mind at ease about that one component of my purchase please... ;) Those telling me they will wander and follow the pavement for X amount of miles have my brain in overdrive wondering how bad it will be....
Reactions: hoseclamp
Just occurred to me there is one 20" wheel option. There's a company down in Vancouver BC, they can make any wheel. Steel though. I'm going to send them a steel 19.5 wheel, copy it but in a 20", 7.5" wide. Down side, no simulators will fit, I'll let you know what they say. Cost I expect $3g cdn. Hmmmm
Banned
Discussion Starter · #23 ·
Steel would count me out. If I'm going to upgrade for tall cash, it would have to be aluminum. Curious to see what you find regardless though...
F350 Tow Boss or F450
Second on the steel - it would work if I only planned on using it for winter. I thought about taking a 20" and having it narrowed, but then remembered too narrow and your tires will rub (since there not tall and skinny on a 20". Would love to hear feed back on the XDS2 as well. I was concerned about speed rating as well. I'm no speed demon but doing 80 consistently would be a must. I did talk to Rickson once and they said the speed rating was at a max load, and if your not pushing the tire to max then they could go faster. But seems like that just leaves you open to potential problems. Also I would think running so called drive tires on front would be a must. For me a little bit of snow or ice and 4wd is a must on a dually, and having slicks up front just seems pointless. I did run a set of Toyo AT2 tires on my truck for a week, and seems like those wandered all over the place and found every rut in the road, so I'm assuming that's what the 19.5 will be like in the beginning.
Problem with 22"s is that they are bit spendy (ok very spendy), a bit big my taste, and with the lower profile sidewall and heavy wheels don't know in reality if you'd gain much in ride quality, and with a 11.67" wide tire times 4 on back not sure if it would help for traction in snow either. I definitely can see them being beneficial in mud though.
SOB stupid computer lost my novel. lol
Short version, I'm testing the 4 tires on the truck when it gets in, now next week since the company hauling it went to sleep this week for some reason, going to test footprint and casing flex on the steering axle with what psi etc. Wouldn't be the first time a higher ply tire rode better or had better squat, who knows. Side note, you guys should look at the pic I put up, the toyo m920a, looks like a brilliant tire, the quietest out of anything I'm considering too I'm sure along with least bump steer and wheel feedback. It's also 87mph rated, I don't like having a speed rating I can exceed several times a day, the odds of anything going wrong are low, but I still don't like it. For the winter, casing flex and traction are the priority.
Also SC, to clarify the 20" wheels won't clear the calipers, the inside of the wheel I'm assuming is thicker than the stock 19.5" wheels (cheaper aluminum and manufacturing imo), wheel width is not the issue.
To clarify, the four tires are xds2 12/14 ply, and toyo and continental.:)
12 ply Michelins didn't show up for some reason, trying to find them.
We have the part #, they just didn't show up on the truck yesterday. Regarding the 14 ply tires, heaviest was toyo, then Michelin, then continental. Flexible casing, stiffest also toyo, then Michelin, continental was the most flexible. Hoping to see the 12 ply xds2's before the weekend.
Will definitely be interested in hearing your reviews. If the 14 plys ride okay then that'll open it up to also being able to run 245/70/19.5s. All 3 of these tires look like good options. Hopefully with the F450 going back to 19.5s and the wide variety of 19.5 wheels now available for "passenger" trucks well start to see more focus to improve these tires.
Using 14 ply xds2's. 12 ply not avail anywhere. Add in some studding and we will see how it goes. Truck arrived last night, undercoating and rhino lining the box today. Should have some feedback on the tires by Monday.
Banned
Discussion Starter · #32 ·
That's awesome. You must be excited. Looking forward to reviews on the truck and the tires...
I've run the XDS2 (14 ply) on the drive axle for a couple of years now. Noisy, compared to the stock tire. I run stock Continental HSR's on the steer axle.
The XDS2 has 1,000 sipes and 400 tread blocks. I've never had a tire that came with more factory cut sipes. Speed limit of 75 is about even with the maximum speed of my truck, with 4.88 gears. But since I only drive 65 miles empty, and 55 miles towing (maximum speed limit in my state when towing) I haven't had any issues.
I have had 3 steer tire blowouts on the highway at speed with General 19.5 tires. Survived all of them, didn't hit anyone, but will never, ever, buy a General tire again. Ever.
Sportscraft, you mentioned running 245's, but it is unsafe to do that on stock rims, which are only 6" wide. 245s (in the 19.5 rim diameter size) require at least 6.75" rim width. This is important, because unlike even size rims like 17s, 18s, and 20s which have a steep 5 degree bead retaining taper, the half size rims like 19.5 have a much shallower 15 degree bead taper. And, the 14 ply rated tire is rated all the way up to 110 psi. Mismatching the manufacturer recommended tire to rim size is not something to disregard lightly. Like I said, I SURVIVED three steer axle blowouts, with correctly match OEM tires to OEM rims... and those were not pleasant experiences. No way would I ask for more probability of trouble by ignoring the warnings of both the tire and the wheel manufacturer.
Something else to look out for is dually spacing. The 6" rims do not have the offset to maintain minimum dually spacing for a 245 tire, never mind the shoulder support for the sidewall and bead retention in rim width. If you want to run 245s, be prepared to also change rims... which of course adds substantially to the cost, and for what, when the 225 in LRG has more than enough capacity for any load an F-550 chassis cab is rated for, much less an F-450 pickup.
Hoseclamp, running a 14 ply steel corded sidewall tire at 40% of the rated inflation pressure is a recipe for zipper failure. The manager of your tire shop may not have any concern, but Michelin sure would, as would any other heavy truck tire manufacture, the Tire Industry Safety Council, the Rubber Manufacturer's Association, and the Tire and Rim Association. Ford would have concern also, and I'll bet Ford provides some guidance in this regard in your new Owner's Manual.
When a steel corded sidewall tire is underinflated, the steel sidewall flexes repeatedly, over 640 times per minute, and even more times for you, because you drive faster than I do. With lower inflation, the excursion of steel flex is amplified, leading to metal fatigue. The fatigued metal can separate, like what happens when wiggling a soda can back and forth too many times. When it is time to haul the XLR and you inflate the tire to match the load, the weakened sidewall may no longer be able to withstand the increase in pressure, and can suddenly blow apart at a fully fatigued portion of the sidewall, which near instantly propagates into a zipper failure with catastrophic results.
The increase in pressure doesn't necessarily need to come from the act of inflation. Heat build up in the tire from use can increase the pressure, and this would be compounded by the underinflation, which flexes the sidewalls generating more excess heat. Ford, and all commercial tire manufacturers recommend, that underinflated 19.5" tire and wheel assemblies be removed from the truck and inflated in a safety cage if the underinflation was less than 80% or less of recommended operating pressure. Your tire store manager says it's ok to run 110 psi rated tires at 40 psi. That isn't advice that I would heed. Even if your door plate recommended operating pressures are at 75 psi, 40-50 psi is still substantially less than 80% of even that reduced operating pressure.
For corroborative information, see the very first page of Michelins Truck Tire Data Book, The Rubber Manufacturer's Association's Tire Information Safety Bulletin #33, or simply check out the relevant pages in your new truck's owner's manual. You will find they all agree with each other, and would disagree with your tire shop manager.
Besides the safety aspect... and when they say serious injury or death, they aren't kidding, just check out some you tube videos from Russia and Asia of truck tire reinflation accidents in the shop... there is also the financial cost of underinflation. The following guidelines are from tire manufacturers, who you would think would keep this information a secret so buyers would wear tires out faster:
• 20% underinflation can reduce tire life 30%
• 30% underinflation can reduce tire life 40%
• 40% underinflation can reduce tire life 50%
The XDS2 tires are $400 each. By recommending 50% underinflation, that tire shop manager appears to be attempting to double his business with you, if you are still around to pass him your credit card.
I like the XDS2s, but back when I bought them, the Toyo M920A hadn't been invented yet. If I lived in snow country, I'd be sorely tempted to try them, based on what little I've been able to research since your post first introduced me to them. My principal concern is wet traction, light snow, and black ice. Mostly wet traction. I don't drive in heavy snow pack like you Canadians have to. One thing I do not worry about is tire wear. Thanks for calling attention to another tire choice in this size range.
And congrats on the selection of an F-450. The Dana 130 axle that comes with the F-450 is underrated for the weight that same axle is normally rated to carry, I believe in part to compensate for the fact that the Dana limits the power input to the S130 axle (at it's maximum rated weight carrying capacity) to a level less than what the pickup engine produces. For more information on this, see the Dana Spicer website information on the Dana S130 axle. It is rated for more weight, but less power input. I think that could be why Ford went with the S130 in the 2015 and up F450 pickup, rather than the S110.
Banned
Discussion Starter · #34 ·
Great, informative post NYB!
A good read, but are we under inflated with a lower psi is the question. This truck has a recommendation of 90/80psi fr/rr, loaded. Running the same pressure empty keeps ford's lawyers happy, and whichever brand of tire brand's lawyer happy, but unloaded, it's a recipe for poor traction, ride, and tread wear. You can easily run less air in the rear without being under inflated, been doing that for years. My biggest concern, when does low air pressure effect the bead seating on the wheel, and the answer is no issue running 45-50psi in the rears, as long as the sidewall squat suits the load. On my '13 f450, I ran 235 wide winter tires on the 6.5" wheels, 1,600lbs in the bed, 70-75 front 50 rear gave an excellent footprint with great stud penetration. On this truck, I see descent sidewall squat on the fronts already, so I don't see much point of dropping pressure if any a little, much like on the '13 truck. The rears at 80 psi, easily I can see outer edges on the rear tires aren't even on the ground (7.4" wide tread, 1" per side not making contact). Throw the weight in it, maybe 60 in the rear gets me a descent footprint and some traction. Maybe I bump the weight up to 2,200lbs (1/2" x 4' x 8' steel sheet added). Either way, regardless of the tire's max psi, you can safely run a lower than door psi, without compromising safety, as long as it's done properly.
That's too bad with the HSR's, I've ran good continentals, no bad yet in various applications, that might be the motivation for some nicer riding michelins for the spring:) A set of XRV's or XZE's all the way around would ride great.
Studded and mounted on steels, using simulators, best to have for the winter. Looks good!!!
Banned
Discussion Starter · #37 ·
Excellent... Extensive road review required! ;)
21 - 38 of 38 Posts
Status
