Ok,I suspected a week starter because it was getting to the point that I couldn't try crank my truck but a couple times and the starter would get real sluggish.
So i've replaced the starter and the sol. on the fender(which looks different than the factory one)'Looks more like the typical ford solanoid!Before I started this project I had
the battery"s load tested and was told they were fine.New starter is in with new solanoid on fender and will hardly turn over! I did buy mitsu. unit from auto zone.Now when I try to start it goes good for a second then everything gets real dim and slow.I did notice the Positive Cable started smoking! Am I looking at a bad ground? Thanks
N2ofreek
N2ofreek
