Hello all,
It's been a frustrating weekend. After months of trouble free service, my truck is stalling a dying from a persistent air leak. I was stuck on the highway a few times on Saturday getting down to Puyallup here in the Seattle area.
Here's the situation:
1. You all know what it's like when your truck runs out of fuel, starts slowing down, no power and it dies. Same happens here.
2. I installed a clear fuel filter for a gasser with the element removed to watch for any air bubbles. It's installed on the line where the water/fuel separator would be. When the engine is running, I can see a steady stream of bubbles being made from the side that sucks from the front fuel tank (i've not used the rear tank due to it getting filled with gunk it will be drained and cleaned this summer). I put in a new section of fuel line since biodiesel degrades rubber compounds with re-tightened fuel hose clamps.
3. I looked over the fuel lines coming from the tank and there are no apparent fuel leaks, I checked the connections at the tank and their tight as well, I put in new retaining clips a few months ago. I put in new fuel injector return caps and hoses last summer. A new fuel pump and IP were installed last September as well (sure hope the IP isn't going on me, but with the amount of air coming into that clear fuel filter, I think the IP is just fine.)
With that out of the way, my question is this:
Could this be a problem with the fuel selector valve? Does this valve contain any rubber parts such as o-rings that would be attacked by ULSD or biodiesel?
Sorry for the long post guys, I like to keep things short and to the point but I want to be as detailed as possible to narrow what the hell is going on here.
