1 - 20 of 23 Posts
Hi guys I recently purchased a 01 with 13800 on it. I'm gettin ready to do the first oil change. I'm thinking the rotella 5w40 synthetic. But what about the filter? Also wondering what other good maintenance stuff I should do. The tranny fluid is good for amity 9000 miles but I'd like to drain the pan I guess? And and some fresh ATF.
I would save myself some money, and go with either Rotella 15w40 or Motorcraft 15w40, and a Motorcraft filter. You can get the filters at Walmart.
I would do a complete transmission flush, there is an excellent DIY write up here on this forum.
I use synthetic 5W-40, many people in the forums sing it's praise because they get quicker starts in winter time. If you're changing your oil like FoMoCo says you should, the regular oil should be fine, unless it gets much below freezing a lot where you are.
Steer clear of Fram filters. You can get OEM Motorcraft filters from Wal-Mart for a good price, they are good filters, but not great filters. Some of the highest quality filters you'll find are the Purolator PureOne, and the Mobil 1 filter. Presently they're both just under $20 at Advance Auto.
Other people have found they can use larger filters designed for Caterpillar engines on a 7.3. I have a Donaldson ELF7405 that I'll use on the next oil change. I had two delivered to my front door for about $27 each. It's 98.7% efficient at 15 microns, and 50% efficient at 7 microns, and holds at least 1 more quart over a standard 7.3 filters. That's exceptional for a full-flow lube filter. Other people speak about using Fleetguard models and such, but I don't recall all the data.
I'd service that transmission pronto. But beware of what some shady people market as a "flush." Not all flushes are the same.
I would just drain and refill the tranny and install a new filter, but I would not use any kind of flush chemical or machine. As for the oil, the 5w40 Rotella is great, especially in the winter, but it's just fine to run this time of year too. With that said, I'd just run standard 15w40 and save some money now, and use the 5w40 if you are in a really cold climate when winter rolls around. I believe Motorcraft filters are made by Racor, they are great and it's what I run if my local shop runs out of the Donaldsons.
I just slapped a Donaldson ELF7405 on my 02'. Here are some pics comparing it to a Purolator PL44872.
If you are planning to "change" your tranny fluid by removing the drain plug save your money. You can drain about a quart from there. Still leaves 18 or so to go.
Discussion Starter · #12 ·
well i would like to tackle the oil change this weekend. so i think im going to have to put that donaldson on, on the next change. which i will do right before winter when the cold comes in. I dont think any local shops sell that filter so it'll have to wait for now. but i think im also going to do the tranny fluid in a week or two. so im going to to start reading the diy thread pretty hard.
Well, order a few online and slap one on when you get it next week.
The FoMoCo Motorcraft filter will only run you a few bucks, and you'll lose only about 2 quarts of oil when you remove the old, and you'll have to add about 3 back with the ELF7405.
Fulltimer: 286K miles on the stock trans and still shifts and performs good... I'm doing something right!! Guess that synthetic stuff is really not that bad after all...
And I tow yr round... 10Klb--> 5th wheel Jayco then during the winter months a flat bed w/8- 4wheelers aboard... I also was smart and added an extra trans cooler inline with the stock cooler... My temps never get over 180F... Then the spin-on by-pass Trans Filter just adds that extra clean trans fluid pumping through out the 4R100... That so called extra 2.5gal is still almost like new since I drain once every january... Hmmmm
So the way I do things are working out pretty dam well... I would say...
OK... Back on Topic~
That is impressive for an auto. I've been running synthetic Mobil 1 ATF for the last year in my ZF6 and it did seem to help a little with early monring cold shifts when it gets below freezing, good stuff IMO.
Discussion Starter · #17 ·
Ive heard of adding that cooler. where would you pick something up like that? i do quite a bit of towing myself. I belive im going to do mobil 1 synthetic for the fluid as well.
Bobby: PM sent! URL is not a vendor so I didn't paste it here...There are a few coolers to chose from... I just chose the V10 cooler, which was installed with the Ford V10 motor...
The cooler which came with the 6.0L PSD is a very popular model... I think there are 2 or 3 versions...26row and 31row I think...But for a new one they are pretty pricey... Some have installed used ones, for a lower price... {Ebay is a good place to find them}... I myself wouldn't install a used Trans Cooler...
I don't tow heavy 24/7 so I didn't feel the need for the large 6.0L cooler... This cooler really helps with trans temps... awesome coolers...
I payed half what those coolers cost, and the V10 cooler run parallel with the stock cooler does a great job...
Is it the perfect set up? No! but it works very well for my application...Everyone's is different... FWIW--->M1 ATF is a great product... Synthetic is the way to go in the trans if you do any type of towing...again... JMHO...
Found 2 V10 coolers on ebay... sent you a PM with URL... one has a thermal by-pass for cold weather climates... I think one is the older model and the other the newer version... both are same size and same GVW Rating 40K... Ok I see the LPD4739 includes the by-pass and the LPD47391 does not, hence the cheaper price... It is crazy how the price of these coolers just keeps going up... The more people buy them the faster the price goes up...
I have run 14 qrts 15-40 rotella with 1 qrt lucas full synthetic oil stabilizer for the last 6 yrs w/motorcraft filter I currently have 903,567 mi.on original engine although it is finally showing the miles of wear compession is a little on the low side but, it still runs very well and it is still driven 4-5 days a week.I was hauling commercially with it for the last 6 yrs in all types of weather form extreme cold to extreme heat although full synthetic oil would give easier starts in the extreme cold I have never had a problem getting her to fire up with the 1st cyclying of the glow plugs keeping in mind everything was always kept in tip top shape GP's batteries...etc.My oil changes are always done every 7,500 mi. give or take a few mi.every 6 mths.I have an oil annalysis done to keep tabs on the inners the last test was done with 900,000 mi. all is still good nothing out of the ordinary.Everyone has there own maint.routine once you start a routine stick with it as I have.I'm hoping to hit a million before putting the new engine in I should be able to reach the goal now that it's not hauling the heavy loads anymore.Goodluck! Mike
1 - 20 of 23 Posts
