My fuel filter light flickers when my truck is idling. When I move off idle the light goes off. I would think if the filter is plugged this would be the other way. By the way the filter is not that old.
Check the wire coming off of the switch and see if it might have a bare spot in it touching ground.
Why would it just flicker at idle and not all the time, if it was a ground issue
Engine vibrations change from idle to higher RPM. You might also check the vacuum switch. Just unhook it and see if the light still flickers. It obviously isn't a fuel filter stopped up, because it only flickers at idle only.
