Sorry if this is in the wrong section of the forums, but over the last couple of weeks I have been smelling wet carpet smell and finally found where it is coming from today while cleaning the inside of my truck. The track under the kick plate trim along the passanger side of the truck has been holding moisture (front and rear door). I looked under the cab in hopes I would see a rubber plug missing but there doesnt seem to be anything out of place so I'm not sure as to where it can be coming from. Has this happened with anyone else. I did a quick search but only came up with coolant smells which is not what I'm smelling. I thought that it may be coming from the a/c condiser but not sure if that is a real option.
thanks for any help that anyone can provide!!!!!
