1 - 9 of 9 Posts
I'm changing out engines from an auto. to a manual and need to ask. The manual has what I think is called a dual mass fly wheel. I have heard of them but don't know anything about them. It looks OK but I need to know before I put this critter in if it has problems. Should I put just an ordinary fly wheel in. Or what? If I remember right there was something about balance. Please enlighten me about these.
Your changing engines or transmissions? If your changing engines then just transfer the flywheel from the old engine to the new one.
A dual mass flywheel is two seperate parts that are connected to each other using some strong springs. If the springs are intact then it is most likely good to go.
There's a test procedure you can do if you have the right tools. It involves securing the outer portion to a sturdy bench, and devising a way to turn the hub portion with a 3/4" drive torque wrench. No movement between the flywheel sections should take place until a minimum of 425 lb-ft has been applied.
If the donor engine still runs now, simply listen for noises coming from the flywheel. If you hear any it's junk.
The truck that I'm rebuilding from the ground up is a 89 four wheel drive with the stick in it the motor had a blown head gasket and a cracked block .The donar is out of an auto. and had a broken fly wheel. I have it ready to put in and wanted to know if that type of fly wheel had any known problems because I have never seen one before. The fly wheel and clutch looks good or I would of already changed it. Thanks for any information.
Automatics come with a flexplate. Remove the flywheel and clutch from your original motor and install them on the "new" one in place of the flexplate.
E40D has a flywheel and a flex plate, check your manual. Normally you'll never see them apart though :)
1 - 9 of 9 Posts
