Well I've got a few questions....like what are the specifics for the ring gear in an 84 F250 6.9L? (see sig) Teeth? ID? OD? Pitch? Also same for clutch and release/TOB. Can it be replaced with the engine *in* the truck, IE with a tranny jack can I pull the front and rear shafts, and then the tranny+xfer case assembly and get to the flywheel to change the ring gear and/or clutch? I know I need a new ring gear (flat/dead spots heh) but I think the clutch is fine, just might need a new TOB while I'm in there...then again while I have it apart I might decide to go ahead and replace the clutch in there. Especially if I can only do it by pulling the engine. Heck I don't even have access to a big enough hoist or cherry picker to lift the engine out.....atleast not with the tranny and xfer case still attached.
I know the TOB has issues in these, and I'm definitely experiencing either firewall flex or bad TOB, I have to diagnose that here sometime soon. On a hot day it's hard to get the truck to totally disengage. It's only an issue for me going into reverse or putting into 1/2nd to start out. After that going up gears is fine, and going down I just blip the throttle, I hardly notice it because I pretty much do this anyway when I gear down unless I'm really trying for a lot of engine braking heh.
Any help/advice you all could give would be great!
TY!
TY!
