1 - 8 of 8 Posts
Hey Everyone,
What do you think of Ford's comments and offer:
Comment:
We (Ford) will have expert witnesses that will testify that the Modifications to your truck (donahoe racing suspension lift- 4 1/2 inch front and 2 inch in the rear) was the cause of your problems. Also the high level of Centain (unknown spelling) in diesel fuel was the cause for loss of power and diesel odor coming through vents. They admitted my truck has been a nuisance (over 100 days in the shop) and offered ---- Cash payment of $8500 for my troubles and I keep the truck.
My opinion:
I lost confidence in my truck. The $ will not make up the difference of current value and purchase price of next vehicle.
Has anyone got a low-balled initial offer and ford came back with a better offer later?
History:
Other than the suspension and spray in bed liner, my truck is in mint, stock condition. (Ford's engineer made comment on how nice the truck was). My suspension installer will testify that the lift did not cause my engine problems. I have brought my truck in 7 times now for loss of power, 8 times for fumes, several for oil leaks and I have well over 100 days in the shop. The day I picked it up after ford's engineer inspected the vehicle (nothing found wrong), I drove straight home and parked it in my driveway, as I walked by the front of the truck, I noticed a fresh drop of fluid. I crawled under the truck and noticed the transmission cooler lines into the radiatior were leaking both sides. I brought it back to the dealer with less than 4 miles from pick up mileage. They found the leak and repaired it. Either engineer caused the leak with his inspections or he's blind for not seeing it. One ocassion, I was pulling out of a parking lot and my loss of power happened and I was almost hit by on-coming traffic. (Safety concern)
I own my truck (completely paid off). I am not hurting for money in anyway. I was told trial would not be scheduled until after 7-27-06. I am in no hurry. My problems started at 800 miles (documented by invoices). I have nothing to gain by jumping at the first offer. I would like a replacement truck and refund of cost of lift and spray in liner. I don't want pain/suffering $. BTW --After 2 years of complaining about the fumes/odor coming through the vents, two weeks ago my dealer did a smoke test for the first time. I had a "decent" size leak out of the right side exhaust manifold. They replaced the manifold and put on a gasket. Would the dealers and ford be liable for the exposure to the fumes and not doing the smoke test as the TSB suggests?
Any help/opinions will be greatly appreciated.
Motofan
Wow, this is a tough one. I would say if you are in no hurry, you are not happy with offer, and you have the means, then wait it out and pursue the issue. That is what it sounds like you want to do. Diesel fumes is a serious issue, so even if you took the $8,500 you would still have to take the truck to a diesel specialist to get it fixed. Good luck bro.
Hello,
My 01/04 F350 just came out of the dealer again after 11 days for continuing Oil Leaks and Exhaust Fumes in the CAB. This time they removed the engine and took it down for Bed Plate seal. They really gouged my frame up with jack marks and removed paint and under coating.
Certainally inferior quality work with no regard for the customers property. And all the mounting bolts are in different locations like they had alignment problems going back in.
Oil Leaks not fixed yet! This was there 5th try since 8/05 and 17K miles.
Originally they said they would not look at the Exhaust Fume issue again. They had already replaced turbo hose and clamps that were found leaking black carbon on to firewall.I filed a Safety Complaint with DMV on the Exhaust fume issue. When the engine was out they indeed did find 1 exhaust manifold cracked on the backside with black coming out of it. So they wound up replacing both sides and added the steel gasket. After 250 miles no more Exhaust smell so far?
I've had loss of power and shutting off in the road. 3 -- EGRV's so far. From reading these posts I believe I have a Turbo issue as well. I'm down to 12 mpg from 17/18 as high as 20/21 trips.
COULD YOU TELL ME HOW YOU GOT YOUR CASE STARTED -- THANKS!
I'd tell 'em to stick it! Your lift didn't cause any engine problems, and their just trying to lowball you. If you can afford to, I'd let it go to court, and try to get a new truck. Just my opinion.
They will settle with you before it goes to court. They (Ford) have NO INTENTION of allowing your lawyer (or anyone elses) to get his hands on all the documentation that Ford Corp has on exactly what problems and how many they have had. If it actually went to trail your lawyer could request this info (and Ford would be legaly obligated to provide it) through a process called "discovery".
When they bought my truck back their initial offer was to simply make 2 payments. I told them to shove it and ended up with a full buyout, check for $12.4K (this was after subtracting for mileage) and balance on truck loan paid off.
This is an easy one. Go the your local dealer and get the paper on the BBB Lemon Law and fill out (one page) and send it in. It sounds like you more than qualify for a buyback. I am at the tail-end of the process and it is relatively quick and painless, just do your homework and have all records and receipts. Good luck!
Have had my new truck for 5 weeks.
Process was simple, I sent in the BBB Auto Line Papwerwork. Had to do that since I got the truck on A-plan and didn't want the family cut off.
Then got a lawyer to accept my case. Then rejected Fords first 3 offers. On the 4th try they got it fairly right.
Just know what your state lemon laws are, and keep quoting them to the Ford reps.
Good luck.
Good luck.
Why would buying on the A plan affect the family.I don't have a prob with my 05 but if i do i would'nt think it would effect my family's ability to purchase a car.Fill me in .
1 - 8 of 8 Posts
