My 02 f250 four wheel drive will not kick out of four wheel drive low when you try to switch the switch back to two wheel drive. Does anybody know what wrong?:frown2:
If you read the other post you would see it is the solenoid on the t case. They are weak electric motors and are prone to giving up when you need them most.
Mine did that once and ended up being a relay issue under the hood
You need to be in Neutral and the brake applied to shift out of 4WD LO.
Back in the summer while backing our camper in a space up hill, I had to use 4wd, I used low to have more power. When done, I shifted back to 2wd. The truck was stuck in low. We drove to the campground entrance and I stopped and pondered. I shifted to reverse and backed up 20 ft or so and it switched to 2wd. First time that has happened. It was also the first time I backed a heavy load up hill spinning a little.
