a few questions, does the fuel going from the fuel bowl to the fpr all run thru the screen in fuel pressure regulator? If so if it clogs it would obviously run poorly?
On the bottom of the FPR there appears to be a black screw on filter housing. Is there a filter inside?
I'm working on my 95 F250 auto 4x4
Thanks!
There is a sock-type screen inside the black housing that you can clean. There is also the regulator screen. They can affect performance, so cleaning them is not a bad thing. I can't remember if all the fuel runs through them or not, but I think so. Cheers!
Thanks patrick. Can black filter cover be removed with the fuel bowl back in the truck?
