I have read several posts about this topic but have not seen any that were solved. If there is a thread to a resolved issue like this, it would be great if someone directed me to the post. So I am posting my issue to seek help. 2016 - 6.7 with 21,000 mi. Changed frame mounted fuel filter, o ring, canister, water sensor and drain plug and under hood filter as well. All OEM parts. Filled canister with diesel, tightened to the stop. Did not over muscle the canister. Cycled key 10 times.
Will not start. I can hear the pump running each time.
So, I removed the discharge side of the secondary filter and connected a clear tube. Not getting fuel out of the upper filter only air. Where else can the frame mounted pump suck air from? Repeated the process at least a dozen times looking for what i messed up, still no clue same results. HELP
