I want to replace the fuel pump with an OEM, but am having no luck finding one. Not even the local dealer has one. I won’t even consider a junk yard. Diesel O Rings has a Bosch, but I know nothing about those pumps. My OEM has lasted 21 years and 147k miles. Any suggestion on where to get an OEM pump, or a recommendation for an aftermarket?
I have had pretty good luck finding some “NOS” parts for my van on eBay.
Is eBay item 223602302138 the pump?
I'm thinking that the OEM Ford pump is likely made by Bosch.
I believe that other guys have had good service from Bosch pumps. Diesel O Rings has good products and would stand by them.
The pump you need is the one that tcnofh1 posted if you want to go OEM (Motorcraft).
This is another option: https://parts.autonationfordwhitebearlake.com/oem-parts/ford-fuel-pump-f81z9c407ac?c=Zz1mdWVsLXN5c3RlbSZzPWRpZXNlbC1mdWVsLXN1cHBseSZsPTQmbj1Bc3NlbWJsaWVzIFBhZ2UmYT1mb3JkJm89ZS0zNTAtZWNvbm9saW5lLWNsdWItd2Fnb24meT0xOTk5JnQ9eGx0JmU9Ny0zbC12OC1kaWVzZWw%3D
(the picture is incorrect).
Discussion Starter #4
I ordered a Busch from Diesel O Rings.
Just as a followup, the Bosch pump that I received from Diesel O Rings, is the exact same as the OEM; name numbers and everything. Only much cheaper than others parts houses.
Glad to hear! Thanks for the follow up.
