I have a slow coolant leak. When my truck is idling I can see antifreeze dripping down from underneath the engine on the passenger side rear near the starter. I don't see any leak near the heater hoses from the top so I am thinking it is probably a freeze plug.
Is the freeze plug difficult to replace or something I could do myself?
Any special tool required?
Ok to just get them from Autozone or Oreilly or should I get better quality ones online somewhere?
Thanks,
Chris
Freeze plugs are easy to change if you have access to them. There is a install tool that you will need to get.Tool is cheap.
I wouldn't buy a rag from the zone, even if I needed a dirty one.
Made-in-USA parts are not usually so much more expensive to make me risk cheap crap. These bore plugs are Federal/Mogul. I got the PN from RockAuto and then shopped everywhere else. They probably came from Amazon or ebay.
(click this text)
I have the Snap-On tool set for installing them, but I only use the disks - not the long swivel rod (which never works, even when straight).
We used to just pop them out with a screwdriver and replace them using a block of wood to get them to seat.
But I would make sure that it is the freeze plug that is leaking before I went to the trouble of pulling the engine to replace them.
If you have to pull the motor to replace a freeze plug he will have to replace more than just a freeze plug. ;It could cost $1,000 to do all the work necessary to not have to wrench on something down the road.
