Does neone know where to get an outter axle bearing? i dont think the powerstrokeshop.com front end rebuild includes them.
· Administrator
If you mean the needle bearing for the outer stub axle, you can get them about anywhere. Just ask for a B2110.
If you buy the complete rebuild kit from Powerstrokeshop that includes wheel bearing/hub assemblies, there will already be one of those needle bearings installed inside each bearing/hub assembly.
Hope that helps
have the pt#'s for the u joint and axle seals for the drivers side?
thanks Klansen it does help, i was also confused about how my model/yr combo has the dana 50 front.. is that gonna matter with purchasing this kit>?
