I second the massive "C" clamp...and a BF sledge. Grab some slide lube/anti squeak goo and inspect everything else while you've got the wheel off.
ON a side note, when I put my new pads on, I didn't measure the distance between rotor/pad with a gauge or anything, assuming it wasn't necessary. Is there a minimum/maximum distance that is necessary between the pad and the rotor?
