1 - 11 of 11 Posts
So, I'm driving down the road at about 35 mph and if I hit a little bump in the road the front end starts shaking as if the whole truck is about to explode. I have to slam on the brakes and slow down to about 20 mph so that it stops. Other than hitting bumps in the 30-40 mph range the truck drives fine. Any suggestions as to what this might be?
sounds like a sterring box problem, I heard some were TSB's.
I won't give a long technical rendition of how resonance works as a force multiplier against the natural frequency of a part or system of parts. Last time (s) I did it seemed like wasted effort. Anyway I will cut to the chase. You have mechanical looseness in your front end. Once excited by a bump or RR track all it takes is a much smaller source force, like slight tire imbalance or road energy, to keep it at a high amplitude. Bet it goes like this. You hit a sudden and severe pot hole, RR track or sharp bump and that gets the force going. Then no matter what you do it keeps on going until you come to an almost complete stop. Can be scary. Example, someone strikes a big bell with a large hammer, it resonates net more energy than the input as a force multiplier and then someone uses a smaller hammer to keep the energy excited so it doesn't degrade. That is what vibration is the mechanical degradations of energy. Your problem is most likely looseness in your ball joints, tie rod ends and related front end parts like shocks, not likely the steering gear but it could be in combination with other things. The steering damper, if anything would damp, but not be capable of critically damping, the energy. Plain as mud? Long and short of it is to find the looseness and fix it and or lower the source force because there is always going to be a pothole or RR track somewhere can't get rid of those. Sometimes it is a matter of balancing some over-sized tires a lot better in the couple plane. That is often simpler than stiffening, removing looseness, the front end or front end parts. 106
Discussion Starter · #9 ·
I won't give a long technical rendition of how resonance works as a force multiplier against the natural frequency of a part or system of parts. Last time (s) I did it seemed like wasted effort. Anyway I will cut to the chase. You have mechanical looseness in your front end. Once excited by a bump or RR track all it takes is a much smaller source force, like slight imbalance. Example, someone strikes a big bell with a large hammer, it resonates energy as a force multiplier and then someone uses a smaller hammer to keep the energy going. Your problem is most likely looseness in yours ball joints, tie rod ends and related front end parts like <font color="blue"> </font> shocks <font color="blue"> </font> , not likely the steering gear but it could be in combination with other things. The steering damper, if anything would damp, but not critically damp the energy. Plain as mud? 106
I was thinking it might be the shocks because it seems like it's wheel/tire hop, not side to side wobble. I've had the same cheap explorer shocks on it since the lift was put on 40K miles ago. Maybe this is my problem?
Now we are getting somewhere, lift kit, old shocks enough info to make a start. This is what I would do. Jack up the truck and try to see if there is ANY play in the front wheel bearings, take a pry bar and pry around on the tire and ball joint area and try to see if there is ANY play. Any play in either area replace the parts. Lift kit = larger than stock tires, get them balanced as good as they can be and replace those old shocks, they probably are overdue anyway. See if any of that makes a difference. No need to shotgun all these ideas. Try one or two at a time until you get to the point of looseness. It IS there somewhere. 106
+1 for the wheel bearings. Mine went in last week for a courtesy check on my 06. Had the same vibration in a side to side motion of the steering wheel. Also noticed some pulling to the left when crusing or breaking. When the tech got to looking he noticed grease coming out of the back side of the wheel assembly. Said there is a good chance that this might be the problem. New hub assembly being install today and picking it up tonight.
1 - 11 of 11 Posts
