1 - 12 of 12 Posts
I have 150K miles on my Excursion. I am thinking of changing out my front wheel hubs. One went bad a small time ago, I installed a used one for temporary. I am looking for new ones. Is there a brand I need to avoid? Timken advertises a 10 year warranty.... is it a good brand? Is there a way to know? Who made the Ford OEM hubs?
timken are really good and motorcraft are the OEM one. pretty sure SKF are really good to
personally i would go timken or motorcraft
Actually Ford (and Motorcraft) buys their hubs from one of the major manufacturers. Could be Timken, SKF, Federal Mogul (BCA).
I think you'd be fine with any of the name brands. I wouldn't recommend going cheap.
Good to know, thanks for the info
If you can get WARN hubs I've had real good luck with them. Changed my factory hubs out on my 2000 F-350 last year they work great I be used them on my old 1979 f-150 yes ago and they always work good.
When they say hubs I think they mean wheel bearings.
I have had warns for a while and they have been good. Take them off and geese then periodically. Just did mine today and they needed it
:grinbiginvert: is that similar to goose? :grin2:
Or did you mean grease?
Sorry, I couldn't resist
Yes, wheel bearing hubs and locking hubs are different animals.
What can I say I have ducks and geese on the mind. Waterfowl season is coming to a close.
And yes I meant grease haha I love auto correct sometimes
Discussion Starter · #9 ·
Yes, the wheel bearing hubs. Not the locking hubs. Thanks for the feedback.
I went through three of the hub assemblies in the first 100K. Since I switched to Timken's I have not had an issue in the 100K+ since, but when I go on a long trip I always pack a spare. I got caught in a remote town once and had to get one from a Napa store, which only lasted about 30K. Of course, as many of us know, the Auto-locking hubs can go bad too and I switched to Warn hubs years ago.
I had to do the same thing recently. I had to purchase one locally from Oreilly, so I got whatever they had with the longest warranty. I work out of twon and had to get back to work. On the drivers side I used an SKF from Amazon. My only issue was knowing if I had coarse or fine threads on the lug bolts. If you get the wrong ones, you will need reuse the old ones. It been a few months and so far so good.
1 - 12 of 12 Posts
