the upper bushings in my front spring shackle is badly worn. the rubber is gone! does anyone have any of these? How about the spring bushings? does poly bushings last longer than rubber? what should I expect to pay? thanks.....
Yes Poly will last a lot longer than the rubber...The shackle bushings are WAY undersize IMO anyway...You can get them from many different places such as 4 wheel parts...I bought mine through them...Cost me about $60 - $70 IIRC correctly for the entire front Spring/Shackle set.
Good Luck,
Casey
I have my oem front shackles just sitting in my garage, w/relativeley new poly bushings already installed. I put in an RSK and don't need them any more. I'm pretty sure they are the same for F-250 vs F-350. If you want them, send me a pm. Jim
You can get just those 2 bushings from energy suspension for around $15.00.
aslo available through summit racing, were I bought mine.
