I just got my updated front spring isolators. I remember reading a post about how to install these but I can't find it now. Does anyone have instructions for these? Just thought I would ask before I give it a try, might be easy to figure out once I get started.
Thanks,
Steve
If your talking about the plastic pieces at the end of the leafs you just take the weight off the axle and drive a large pry bar between the leafs.
Dave
I just installed these isolators last week. Didn't even take the weight off. I used a pry bar to open up the spring enough to get a 6'long 1" rebar in. Then had my 11 year old daughter stand on the end of the bar. Opened up the spring just enough to install the parts.
Seemed to work best by installing the flat piece first(the one with the tit that fits through the hole) then insert the curved piece from the side. Took about 30 minutes to do both sides.
where exactly does the curved part go?
