The fuel lays in the valley.
See;
Welcome to guzzle's Powerstroke Fuel Bowl Rebuild Web Page
This where I got my instructions and parts.
Something else I did, as long as I was working on it.... To drain the water from the bowl (The water seperator being an integral part of the fuel bowl.) the instructions say to find the bottom of the drain tube (Pipe), place a recepticle under it to catch the water and fuel, then open the valve. Well, crawling around under the truck each time I need, or want, to drain the water is not my idea of convenient. My '83 6.9L had a tube from the seperator to the bottom of the truck. It was easy to see when I looked for it. So.... get a piece of fuel line long enough to go from the end of the drain pipe to the ground, I believe it is 3/8" I.D. fuel line but you may want to check it to be sure, a hose clamp, and a zip tie or two. Connect the new fuel line to the end of the drain pipe, clamp it on, slide it down to the bottom of the engine and zip tie it to the truck. Then cut it to a good length. Mine is zip tied just behind the front axle on the passenger side of the truck. Now I can simply turn the tires to the left, slide a coffee can or something under the fuel line, and drain the water from the seperator.
Admittedly, I can not see the bottom of the fuel line from the top of the engine bay. But I just drain it for as long as I think is good and let it be. It is not like the fuel bowl holds all that much water.
Good luck.
