I noticed a small leak in the fuel bowl area and I took out the schrader valve because that's where I thought it was coming from. After trying to put the valve back in, the assembly broke. Please see picture below and offer any advice. Do I need to replace the entire fuel filter assembly?
It actually used to be cheaper to buy the whole thing (and still may be), but maybe someone here that converted to efuel can help you out with either a fuel bowl assembly or just the regulator. Not sure if you have enough meat left there to maybe drill and tap it to 1/4 NPT and plug it to get you going? Riffraff has new bowl assemblies for about $300. Cheers!
