Does anyone have a diagram of exactly how the stock fuel filter housing works (what lines coming in are for and what and the little special fuel valve that a few of the vendors have designed exactly does on the top right that has two screws that hold it on)? I'm curious to what exactly that little valve or whatever it is does that is on the top right of the fuel fitler housing. Why do you have to have that special made fitting that ITP and Dieselsite have to make a true pressure gauge work or integrate a fuel system into it to work properly? Where does the fuel supply line coming from the tank go to on the housing? Where does the return line going back to the tank go (does it go back into the housing?)? Where do the fuel supply lines that go to the heads go to on the housing? I have an extra fuel filter housing sitting in front of me but not sure exactly what all the ports coming out of it are for.
