I have never changed my fuel filter myself before. I watched a you tube video on a fuel filter change and it showed the guy drain the bowl by turning a switch behind the bowl where does the fuel/water go. Do I need to drain into something or does it stay in the truck? If it drains out where is the drain located? Anything else I need to know?
The drain valve is attached to a piece of tubing that drains to the passanger side of the motor. Some, as well as I , have attached a piece of rubber tubing to it to bring it further down to prevent the fuel from getting all over.
Mark Brown
do I access this tube from under the truck because I looked under the truck and did not see a tube that anything would drain out of and I dont want to open the valve up untill I know where the drain is
· Super Moderator
Look at the front right side of the engine just above where the oil pan is and you should see the tube from the filter housing.
Jim
I found it thanks guys. I would have never seen it hard to find on your back under a 2wd truck. fuel filter was a snap Ill never pay anyone to do that again.
