If i drain my fuel filter and clean out the bowl and change the filter, do i have to do soemthing to fill the bowl again with fuel or not? Can i jsut start it right up? Do i have to prime anything and if so How? Thanks Corey
Just be advised that if you haven't drained your fuel bowl in awhile, after draining and replacing the filter, you may end up having to replace the O-rings on the drain valve. The last time I changed my filter, job went just fine and then the next day I developed a leak from the drain tube. I think the o-rings were stuck in place, then when I drained the bowl I loosened them up and then they leaked.
So, just keep an eye on it for a few days. If you start smelling fuel, or notice it on the ground, this is the likely culprit.
