I have an 03 F350 6 liter. Getting ready to run B100.
Can I use the Factory Fuel Filters and is my Gas Tank ok? I've heard some years had gas tanks that had a liner that would dissolve from the methanol in the bio. Any help or suggestions will be appreciated. Thanks.
There shouldnt be any methanol in your bio. bio is an organic solvent though. The tanks in question are the steel ones and they delaminate.
You can expect to clog a filter or 2 if you dont stay on top of the issue. Bio will clean your tank and lines, and all that stuff ends up in your hfcm filter.
Just ran through a half a tank of my first batch of bio. It came out perfectly. Motor runs significantly quieter. I notice the rpms raise just a tad easier as I drive the exact same way. Even went up a tenth of a gallon more on the dummy gauge. Lovin' it. Gonna run two full tanks and change the filters when I change my oil as I want to make sure I catch all the junk the bio is loosening.
I had a lot of help and advise before doing all of this. It was a long road. Special thanks to Graydon Blair of Utahbiodieselsupply.com and Jason Brown, who comes on here as evolutioncam. Couldn't of done it without you guys...I popped my cherry. Lol.
