Just by chance yesterday I was checking my fuel filter and drained it. The heater wire seemed to be less rigid than normal right where the connector is attached to the wire. Anyway to make a long story short the wire was broken where it enters the 90* connector.
So to check yours disconnect the wire and gently pull/stretch the connector away from the wire. If it has a broken wire you will plainly see the outer covering thin down where the break is.
I intend to fix mine ASAP, they have a junk yard of vehicles at the shop and one will have the end I need.
