1 - 9 of 9 Posts
I haven't seen them anywhere else..
You are speaking of the hard lines not the return lines and caps correct.......
Check the wreckers or ebay usually $25-$50 for the whole set.... clean them paint them and your off to the races.
PETE....I would normaly agree with you but there are some things that I wouldn't replace with used. There is no way of knowing the integrety of the insides of used lines, and it's not like you can "make do' with a quick fix while your broke down in the middle of you know where....Just my opinion
I can agree with you....... did you buy your truck new.... if not then how do you know yours were good....
Without abnormal bends or visible damage they should be fine.....I would think just engine vibrations could damage the innerds of the lines too???
Okay I'll give you that one, but when I bought my truck it was running and it was reasonable to assume that the insides of the lines were NOT rusted out due to exposure to the elements. We might be splitting hairs here...I have very high respect for your thoughts... I was just expressing mine....
1 - 9 of 9 Posts
