As I mentioned in another post, I am replacing the fuel tanks in my 93 f250, 7.3 non-turbo.
The real culprit was the rusted and cracked metal fuel line going from the rear tank to the tank selection unit.
I need to, at a minimum, replace the rusted out metal segment of fuel line between the rear tank and the tank selection unit. Another possibility would be replacing the combo of the flexible line/rigid metal line/quick connects to tank and tank selection unit.
I've been having a hard time tracking down a good answer on what to do as well as high-pressure 1/4" line.
Here's the setup on the piece of line I'm looking to replace:
Rear tank -> quick connect -> high pressure flex line -> rigid metal line -> high pressure flex line -> quick connect -> tank selection unit
The flex lines are not clamped to the rigid, it's a friction fit. Can I just slide the rigid metal out from the flex line and get a new rigid line in, then band clamp it in place, end of story?
If not, where can I get high pressure (nylon?) 1/4" line and can quick connects be installed to it without "the installation gun that's pretty expensive".
Thanks for helping sort out the mess!
