I just had the ICP regulator replaced, "FP" was 46psi according to the shop (the first time my baby has ever been in any other shop than my own). I am wanting to do the "blue spring" upgrade, but want to install a FP gauge. What are some suggestions as far as brand, digital, analog, and where to install the sensor.
Connect the gauge to the regulator test port. You need a hose and gauge with a sending unit the hose and gauge are sold separately. gauge type would be your preference with a 100psi reading you can see the test port here Page 30: Fuel Supply System
The place to connect your sensor is shown clearly in the pic below.
Thanks for the pic goes to Band_Member, borrowed from his thread for installing the upgraded fuel pressure regulator "blue" spring.
It is the "allen head" screw/plug to the left of the new cover. You will need to order yourself the right adapter, then get either a sensor or run an isolator. The isolator will keep the fuel under the hood, so you won't have to run it into the cab. I suggest this place for your gauges, call him and talk to him if you have ANY questions. Awesome guy that REALLY knows his stuff as far as gauges. Also, on his site he has installation instructions for just about any gauge. Check him out.
Thanks for the tips, I am ordering a set this week.
