What is our fuel pump rated at? I pulled the line loose at the ITP delete block and filled a jar. I'm estimating a g/m. My truck has no power. I can't pull a hill without downshifting. It makes no smoke at all. I can unplug the ICP sensor and get 800psi more oil pressure(3200). Which of course makes it run better.
might want to replace the ICP and clean the connector. It might have oil in it. Check the harness as well. Any codes, What is the icp at idle with icp plugged in and not plugged in at idle
Brand new ICP. Swapped IPRs. I don't have a way to pull codes. ICP I think was around 500 both ways.
On another note, when I did the EBPV delete, I also removed the tube from the exhaust manifold. I just left the sensor plugged in and tucked it away. Would that have any effect?
